mine only shows 368 mb on every app i use like antutu go launcher etc etcand my memory is only always about 20 mb free. Please help me guys.
Solved! Go to Solution.
I checked ram again after uninstall antivirus and switched off i got 197 to 208 ram free for fixed
Thank you for your friendly support , One problem solved
If you provide solution of Camera then please share with me...i have no extra problem..
explain the camera issue?
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
If flashed on, picture comes with whitish..i got specification from sony mobile that it has hd camera but qualty is not good , xperia mini pro also has 5mp but its quality awesome..please resolve my last problem.,.
u should read this... http://www.androidcentral.com/ram-what-it-how-its-used-and-why-you-shouldnt-care
having used several android phones myself based on experience i can tell u the amount of ram free doesn't mean anything... android will autoallocate ram it needs as and when it needs them. if a service is running in the background that obviously uses ram, killing the service will only cause it to restart again, wasting cpu cycles and battery... just leave them be...
if u do need to free ram however, i would recommend Fast Reboot. don't use any task killers or ram managers. search around and u will see why they're not recommended if u don't believe me.
anyway... our phones have 512MB RAM, but yes, we only have ~320MB to work with... the rest are dedicated to the different hardware in the phone... cam, audio, etc...
Ok i got it.. now. thank you.. but my camera solution??
have you compared the pictures on a computer or LCD/LED/Plasma screen?
i did it..its come with whitish.. and without flash its come color dot if it zoom it..not clear..like china phone..
I don't understand what you are saying
I want to said that.. capturing picture with flash its come whitish picture.
Like that..
is there any plastic, film, protective case covering the flash and/or the lens, bc that seems to be the case here
