how to view apps
GELÖST
Nicht anwendbar
how to view apps
i'm trying to download file manager but when i hit install button in android market in my PC, there is a message that says "There are no Android phones associated with this account. Please sign in with a different account." what am i going to do for me to put my phone to my google accouunt and to have a successful download of file manager for android.
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Uliwooly
you can also do this
download the apk on your computer CLICK HERE, send it to yourself through email, make sure you send it to your Gmail
now on your phone
go to settings -> applications -> check unknown sources
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
Don't forget to mark the Correct Answers & Helpful Answers
7 ANTWORTEN 7
slimshaddy
Forenjunkie
hmm its a common problem..
you have to log in with gmail account you first looged in with in your phone...
also , even if you download via pc.. the phone will need an internet connection of its own....
Nicht anwendbar
so first i will connect to android market on my phone via wifi?
Uliwooly
now on your phone
Nicht anwendbar
how can i send it through my Gmail? i dont know how because i am just 15 years old
Uliwooly
all this on your comptuer
as the instructions above,
download the APK, open any browser, go to your gmail, attach the file and send it to your gmail, now
on your xperia
open your gmail app -> open the email -> instead of downloading the app you'll have an option to Install
Nicht anwendbar
thanks
Uliwooly
Anytime
