I Forgot My Xperia Tipo Pin. Now What Can I Do ??
I Knw The Pin Numbers I Entered For Security,
But Now The Phone Did'nt Accept That Code.
So Plz Help Me Out.
Thank You.
try this
1. Before you start you have to download the PC Companion software fromhttp://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Once installed on your PC, double-click the PC Companion icon on your desktop to start the update.
Note! For some models you will be prompted to do a backup prior to the update and then restore.
3. Install and open PC Companion then select Support Zone.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
Don't forget to mark the Correct Answers & Helpful Answers
you only have 2 options
1) try really hard to remember it
or
2) repair your phone with SUS, remember that this will delete everything on your phone (your pictures, videos and music won't be affected)
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
for future reference
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
It Says Your Phone Is Already Up To Date.
Now Wat Can I Do To Update My Mobile ?
does it say install?
No.
It Says Your Phone Is Already Have Letest Version Of Software.
that's quite odd, what about PC Companion? have you debranded and/or flashed your phone ?
No.
No debranded or flashed
My Phone Is New And I Purchased It About a week ago.
Sry for my english.
repair it with PC Companion
http://www.sonymobile.com/us/tools/pc-companion/
But The Phone Is Not Connecting To PC Companion.
