I have synced my facebook and gmail contacts. The contact picture appearing in infinite view is too bad to see. Its completely blurred.
Is any one else seeing this problem? Any way to set the pictures right?
Solved! Go to Solution.
I think this a ICS problem not firmware problem.
It's fixed on Jelly Bean http://android.stackexchange.com/questions/24877/why-are-my-contact-pictures-blurry-and-how-to-fix-i... .
tks a ton @calbertoferreira...i was looking all around the phone for any option as such to fix dis..
Is there any way to disable showing contact pic. in infinite view..?? any other work around?
tks in advance..
I don't think you can disable them, but you can install an app like HD Contacts Photos, try it out https://play.google.com/store/apps/details?id=com.ryosoftware.contactphotosupdater
Looks like a grt workaround..
the first instruction for the app is "Place the desired contact photos (in PNG or JPG format) in a folder of your sdcard"...how to do that as I'm syncing my contacts from google sync and facebook ??
Hmm, you're right!
I don't have a better idea at the moment :s
