LT26W Charging Problem
SOLVED
essilva
Visitor
When the LT26W in charging, it will stop charge by itself when the charge is above 100% and de LED show the green light. After 2 hours the charge begins reduce, then the LED show  the red light. And the charge continue reducing until 0%. If I remove the charger and put the charger again the phone begins charge again. Is this normal?
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
that's not normal, repair your phone with either PCC or SUS if that doesn't help take your phone to a Sony repair center.
2 REPLIES 2
Uliwooly
Uliwooly
