McAfee problem!pls help!
Nie dotyczy
hi guys,, i have sony erricson xperia mini pro and i have huge problem..
i have installed mcafee security program and it works ok but 2 days ago, while i was using my xperia as mobile access point to my laptop,, at one moment he just blocked my mobile and wants me to put password to open it! and i forgot it.
on a screen it says,,this device has been locked,please contact(my wifes number, i remember i put her as buddie),to return device.press menu to enter your pin and unlock the device!
then i can choose to write a pin (which i forgot), or if i go on *forgot pin?* he says me,,,a random temporary pin will be sent to your buddies via SMS. do you wish to send temporary pin? and when i press YES,, it open new window,,,Temporary pin error,,please put in a valid sim and make sure there is conectivity!!!
i already checked my sim, and its working in other device,,and conectivity is also good..
what to do,,anybody!! i dont recall that password!!!
11 ODPOW. 11
Nie dotyczy
Hi,
I am having the same problem and it also shows my wife's number to contact. (Hey SE how do you people know that who is THE WIFE from contacts:D ) . well i rememberd my pin so there was no problem unlocking the device. but that was really strange
twinkle49
Hpow do I disable McAfee please?
