moving Bluetooth received file
binu
hello all,
i bought xperia tipo 1 day before. now i am facing a small problem. I recieved a file in bluetooth and i am able to find it in received files.
But i want to move it now to my music folder. But i cannot find a path to this files. Where is this files kept and how will i move it.
Please somebody help me fast
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Uliwooly
use a file manager like OI file manager or Astro File Manager
also you can use bluetooth file transfer
4 ODPOW. 4
profile.country.PH.title
MarlonUk1
Try to download a file manager from Google Play, ES or Astro are good, then browse your sd card for the file and transffert it. you may need to reboot for the sd card to update the new location.
binu
i am having astro(trial version). But i cant find where the bluetooth recieved files are.
i searched every folder literarly.
i came up with another prob nw. i need to delete some files too. What to do?
Uliwooly
MarlonUk1
try to see the settings, show hidden files.
if you need to transfer a file just long press it and select cut or copy .
