my phone got into blind people(voice guidance) mode how to come out of it, i switched off my mobile even though it is in the same mode plz help me out as early as possible.
Ok doing this is no easy task and requires some patience. Please be aware that with all of these steps it will require you to tap on each option twice and for the sliding function you will need to use two fingers spaced slightly apart:
Main menu > Settings > Accessibility > Talkback > Untick the option.
What are your thoughts about this forum? Let us know by doing this short survey.
Im not able to scroll and im not able to operate my mobile properly becoz of this
Please ensure you are following my advice as above on how to scroll etc to disable this function.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
My phone is Encrypted with a Alphanumeric + Special Character password, when i try to type the password, i cant type, how do i Unlock and go to that Accessibility Option to disable it?
You will need to double tap each key to enter the password.
thank you very much...you saved me from insanity!!!!!!!!it almost stopped me from ever exploring my phone!!!!!!!if i coul dcould hug you, i would. thank you very very much!!!! this really hepled
THANK YOU VERY MUCH...I WAS SO MUCH WORRIED DUE TO THIS BLIND MODE..I FOLLOWED UA STEPS AND MY PHONE IS BACK TO ITS NORMAL MODE...THANK UU
