My phone's imei code isn't accepted for the bootloader service?
SOLVED
Marcel1
Visitor
In the bootloader service from sony you need to input your name, imei code and email adress.
I've done that, and then it said: imei code can only be 14 chars long. For my knowledge an imei code is 15 chars long? (my phones imei code is 15 chars long).
So at the end I cannot go further into te proces...
Can anybody help?
Thanks in advance,
Marcel Horemans.
1 ACCEPTED SOLUTION
Accepted Solutions
jalu147
Visitor
Remove last digit of ur IMEI no that will 100% work.
Don't forget to mark answer as correct answer or helpfull answer.
5 REPLIES 5
Uliwooly
is your phone unlock bootloader: yes?
go to service menu
http://talk.sonymobile.com/thread/24534 and check
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
Uliwooly
if it's locked to a network/carrier or network/carrier branded it is not going to work as networks/carriers request this to be locked
Marcel1
Visitor
Yes it can be unlocked.
Rooting status:
Bootloader unlock allowed: Yes
Can't I just drop the last digit of my IMEI code?
jalu147
Visitor
Marcel1
Visitor
It works thanks you. I'm installing a custom rom now. Works like a charm.
