Hi
First time to post. Driven to frustration by my phone locking itself and making screen black during phones call - can be outgoing or incoming. The only fix is to remove the battery and restart phone.
Really annoying as you can't end call if you don't want to leave a voice mail and also really embarrassing if you've called wrong number etc!
Taken it back to Carphone Warehouse (where I bought it from just over a year ago) and they were useless, wanted to send it away for repair. Suggested I upgraded software - it's completely up to date.
Any ideas folks?
Thanks very much
Vicky
Solved! Go to Solution.
:smileyconfused::smileyconfused:
Most probably it has lived its life
Unfortunately service center is the option left for you
http://www.sonymobile.com/gb/support/contact-us/
Before going try this--
Backup everything as it will erase all data on phone (contacts,sms,apps)
Update/Repair your phone via PCC OR SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
Feels issue with the proximity sensor....
Make sure any case , screen protector is not interfering with the proximity sensor
Dial *#*#7378423#*#* in dialer > service tests > proximity sensor > it must be off.... touch proximity sensor and it must show on
do it several times... post the result
Hi there
Thank you so much for your prompt response.
When I select Proximity Sensor it says 'this device does not support this function' ??
Proximity Switch says 'on', I have no option to turn it off.
Thanks
Vicky
or
Hi there,
I'm having the same issue as of recent. I've tried the solution you gave me, i.e. turned on/off the proximity switch. It goes from on to off, and stays at off. What should I do next?
