My Xperia Mini Pro is not booting
SOLVED
Tekere
Visitor
My phone set is not booting once I push the power button.
Please help
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.PH.title
MarlonUk1
try to perform a software repair http://www.sonymobile.com/global-en/tools/update-service/
if it doesn't work I suggest you to take your phone to a local service center
http://www.sonymobile.com/global-en/support/contact-us/
3 REPLIES 3
MarlonUk1
did you try to connect it to the chrager? try to chrage it using the wall mount chrager
Tekere
Visitor
I have charged it with the mains charger to no avail. It just flickers, and does not even show the Sony logo.
MarlonUk1
