I need a little assistance here please.Does anybody know why when i try to add the Xperia P to myphone explorer devices,it says deivce from usb not connected.When i had GB,it worked perfectly,the sistem autoinstalled myphone explorer on the phone.Now with ICS,it doesn't appear.Thank you!
Solved! Go to Solution.
As far as I remember you need to have USB debug activated in your phone's menu for My Phone Explorer to work and to be able to find the phone.
You can find that option by going in to Settings - Developer options - USB debugging - Mark the box
What do you think about this forum? Let us know by doing this short survey.
Yes,i could have never figured out what is wrong,i just didn't think at this.Thank you.
