NEO V NOT STARTING UP !
SOLVED
Not applicable
Hello,
My phone neo v is not starting up what to do pls tell me.
i had unlocked the bootloader.
no custom roms was there.
i can only boot cwm recovery.
pls tell what to do.
it isnt booting no logo of sony erricson .
pls tell what to do
16 REPLIES 16
ayman-d1
Visitor
and another thing,
it charges normally,
the red led light glows and becomes green when it is charged for a long time.
do you know what to do Moderator Nabeel
Nabeel
Master
Was update using SUS successful ?
Was your phone's software modified in any way ?
Take the battery out and insert it again.
Charge until LED goes green and then repair using SUS immediately.
ayman-d1
Visitor
firstly, thanks for the quick reply....
it  didnt help the 1st  tym  updatin usin SUS  and i tried what  u  told about charging upto  green light bt it still didnt work.
the phn's  software wasnt modiefied in any way bt i did installed some paid apps from 4shared ( w/o actually paying).
other than that, i cant figure out what went wrong?...is it a display problm? jst out of curiosity,  can u tell me how much it might cost at a local repair shopto change  the display.
ayman-d1
Visitor
tooked it to a local repair shop.
its fixed now.
the problem was that something inside just went loose.
they just opened it and put reattached the DISPLAY.
there was no other hardware problem.
ayman-d1
Visitor
its fixed now.
they just opened it and reattached the DISPLAY.
manoj519
Visitor
Hi Nabeel,
My Neo V mobile has suddenly got turned off and it is not turning on nor charging or neither detected while connected with USB, i have no idea what to do now..  If it turns on or even show logo then i can do flashing  or somethng. but it is not happening,    Please help me...
ayman-d1
Visitor
hello manoj519
you do no need your phone to be on update software.
you can download sony update service (SUS) and you can connect your phone while it is turned off.
they give you instructions to hold the back button and then connect the usb to the phone.
but AS what happend to me, something went loose inside so i had to go to a local repair shop.
everything was fine just that a plug went loose..
you might also have the same problm but do use SUS to update urself before going to repair it.
