Netflix and AT&T
SOLVED
Not applicable
Netflix and AT&T
I can't seem to get netflix on my play. I have downloaded the app and when I input my credentials, error "Invalid Password". I have verified my credentials on PC and always log on without problems. Any suggestions??
1 ACCEPTED SOLUTION
Accepted Solutions
settings -> applications -> manage applications -> netflix -> clear everything
4 REPLIES 4
Not applicable
Thank you.
go to settings -> about phone -> android version and build number, if you don't have 2.3.4 use PC Companion or Update Service to update your phone
don't forget to backup your phone
Backup & Restore app
if you need the app you can use this link instead to download the apk
http://www.megaupload.com/?d=I5CJUPJV
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
if it's not available and you don't want to wait for AT&T to release it you can debrand it, this is how:
http://talk.sonyericsson.com/message/108961#108961
