NFC not working.
SOLVED
windhund
Visitor
NFC not working.
Hi,
on my phone NFC has never been working. Neither on GB nor on ICS. I tried it with those red an black tags on the SmartTagApp and also with the NFC TagInfo (https://play.google.com/store/apps/details?id=at.mroland.android.apps.nfctaginfo&feature=search_resu...). But nothing happens. I'm not sure if it is the phone or the tags.
NFC can be activated and the symbol is shown on the topline.
Greeting windhund
1 ACCEPTED SOLUTION
Accepted Solutions
windhund
Visitor
I used the repair function from the PC Companion..
NFC is working!
4 REPLIES 4
profile.country.RO.title
_alexdon_
After you start NFC,you should just take the tags where the camera phone is(a little lower) and you should get a message on the phone.
alexdon
Petter
Enthusiast
To be able to exclude what part may be causing this problem it's wise to try with another unit using NFC, such as another phone for example. Slightly_smiling_Face
Try it out and see wether it works out or not. And of course, you need to make sure you touch the right part of the phone. Slightly_smiling_Face
What do you think about this forum? Let us know by doing this short survey.
windhund
Visitor
I think I tried my phones whole backside... Stills not working.
Yes, my problem is that I don't have another phone to try those tags or other tags to exclude that they are broken.
windhund
Visitor
NFC is working!
