Hi
I have xperia Arc, i have formatted the internal storage, and since then my device is not booting at all.
i tried to flash the device but this solution didn'tt work,then i tried via SUS but a message shows that i can't install beacuse the my ROM is modified
So how to solve this problem?
I don't know why you would want to reformat the internal storage, if anything reformat the SD
http://forum.xda-developers.com/showthread.php?t=1324703
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
you won't be able to use neither PCC nor SUS unless you relock the bootloader, how did you formated the internal storage? do you get an error with flashtool?
i formatted it using windows quick formatting, then i tried to flash it but it stops at some flashing stage with error 31
and how to relock the bootloader?
and my last question what is so imortant relating formating the internal storage?
27/053/2012 03:53:37 - INFO - Reading device information
27/053/2012 03:53:37 - INFO - Phone ready for flashmode operations.
27/053/2012 03:53:38 - INFO - Start Flashing
27/053/2012 03:53:38 - INFO - Processing loader
27/053/2012 03:53:38 - INFO - Checking header
27/053/2012 03:53:38 - INFO - Flashing data
27/053/2012 03:53:40 - INFO - Loader : S1_Loader_Root_773f - Version : R4A066 / Bootloader status : ROOTED
27/053/2012 03:53:40 - INFO - Processing kernel.sin
27/053/2012 03:53:40 - INFO - Checking header
27/053/2012 03:53:40 - INFO - Flashing data
27/058/2012 03:58:46 - INFO - Ending flash session
27/058/2012 03:58:46 - ERROR - 31 : A device attached to the system is not functioning.
27/058/2012 03:58:46 - ERROR - Error flashing. Aborted
have you try other ftf files?
4.0.2.A.0.42
4.0.2.A.0.62
4.1.B.0.431
all of these firmwares.
WHAT THE RESULT IS GOING TO BE, FOR ME YOU STILL THE BEST SUPER USER
try to install a custom rom with CWM
Thanks Uliwooly you are the Best, it works with Unlocking bootloader And using SEUS
by the way i checke the unrelated topic and liked it
thank you for that, lets keep that thread alive
