i plugged in my xperia s to check for an update it said there was one so i went through the process-it then got stuck on preparing so i closed it and reopened again it now says my phone is up to date?
anyone know wot the problem is?
Solved! Go to Solution.
If you use SUS only for updating, it won't wipe anything
All data would remain.
Reinstalling the software using SUS results in a complete wipe
thanks it worked! think i'll use that from now on
