PCC isn't repairing my xperia, then when it send me to the phone selection Xperia U isn't there, the same thing happens in the SUS
1 more thing to get back to the stock firmware, I should change the CDF in the build.prop right ?
Thanks every1 in advance
Solved! Go to Solution.
either or, you can choose any phone as this is only to show you how to connect your phone, it won't download the wrong software. you can click on Xperia S (which has the same procedure as the Xperia U)
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
are you sure it didn't say
ST25 Xperia U?
