Hello,
Recently I had notice that I am not able to select the specific text from sms editor nor in any other editor, I was able to do in GB.
when I try to select the text instead of selecting the text and provinding the option like cut or copy, maganifer open up and magnifies the text but cannot select the text nor, So can any one tell how to select the specific text in JB or is this a bug in Xperia go,
Solved! Go to Solution.
You need to double tap on the word that you want to cut/copy or delete..
Hope this helps..
You are much welcome.
Anything that could help bro.
Cheers!
