reset call settings for Xperia SP
sonu_j
By mistake, I seleted "call from phone" as my default dialer. I want it to reset it so i can select from diffrent dailers while calling. I dont want to reset my phn to factory settings, so any suggestion other than that will be apriciated.
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
profile.country.RO.title
_alexdon_
This is very strange.I wonder why the others do not show up.Are you willing to try a software repair just to reset to default that app?
alexdon
13 ODPOW. 13
Danial-mach1
Pasjonat
goto setting>apps>downloaded...tap on setting (upper right)choose reset app preferences
_alexdon_
Try the upper suggestion,if it does not help,try:
settings-apps-all-media storage-clear defaults.
alexdon
sonu_j
i followed  setting>apps>downloaded...tap on setting (upper right)choose reset app preferences, but still the same.. whenever i click on call, it doesnt ask for skype or MVOIP.. it connect through phone dialer.. Slightly_frowning_Face
sonu_j
settings-apps-all-media storage-clear defaults is not enable .. its already default i think.. any other suggestions please..
_alexdon_
Settings-apps-all-phone,clear defaults does not work either?
alexdon
sonu_j
Settings-apps-all-phone,clear defaults is already disable.. it shows no default set
_alexdon_
Settings-apps-all-settings-clear data and restart your phone.
alexdon
sonu_j
restarted with all the above prcedure follwed, not working Slightly_frowning_Face
_alexdon_
alexdon
