Can somebody tell me how to add a ringtone to the main ringtone list. Not the contact linked ringtone, just the general ringtone for answering general calls.
Is there any limitation as to file type or size for this.
many thanks
nick
Solved! Go to Solution.
Hi,
Just Go to Your Main Menu, Settings> Sound> Phone Ringtone (It'll be Under Ringtone & Vibration Menu).
A Menu Appears,
In Default Phone shows the Default & Music File's that plays in Limited/Lesser Time.
Note:
There is no Limitations of No.of Ringtone Files/Amount of Files.
If You want of your Own Music File as Your Ringtone:
Follow the Same:
A Menu Appears,
From that Select the Music ♫ Symbol which appears on Right Top [Opposite to Phone Ringtone Font] & Select the Music File of your Own.
Enjoy Ringtoning
Hope This Will Help You..!!
Mark as Correct/Helpful Answer if It Help's You
Thank You.
Regards,
Siva.
India
Hi,
A Menu Appears,
Note:
Follow the Same:
A Menu Appears,
Enjoy Ringtoning
Thank You.
Regards,
Siva.
India
