When I turn noise cancelling on my WH-1000XM4 headphones there is a very high pitched screeching noise,
I bought them new a short time after they came on the market can't quite remember when. First problem I have experienced. Anyone advise please. Thanks.
Hi @Jamest and welcome to the Community
Does the screeching noise stay on or does it stop after a few seconds?
Either way you could try resetting them back to their factory settings to see if this helps at all.
Have a look Here for instructions.
If this doesn't help then its probably best to get in touch with Support.
Does this happen with all content and all devices? Or, a specific device/content?
And yea, I would recommend following the above steps to initialize it then test it once more.
