Sony Backup & Restore App,,,,
KarloGaderel
Hi, anyone just wanted to ask if there are possible way to view to view and delete the Backup files created by Backupp  & Restore App, coz' the Back up says it will only 5 backups, and overwrite the old one,
but in my case i had 8 of them, and i guess this thing cause me a lot of spce on my memory i just wanted to delete some of it and retain the recent ones, is there any possible way where i can find these file so i can get rid of it?....thanks,,,
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Johan
Guru
I think that should be able to find your backup files here: /Xperia S/Internal storage/.semc-fullbackup.
Connect your phone to your computer and browse for the path above.
4 ODPOW. 4
Johan
Guru
KarloGaderel
Thanks Johan found it and this thing works..
amirr
Thank you very much i found my backup file.:smileyhappy:
Mirardo
Restore sony apps for Xperia xa1 ultra
