Hi
Sony Xperia S Native Navigation App vanished, I probably uninstalled by mistake the 1st time and have my phone backed up after that, so even if I reinstall the OS, when I restore my settings, the app is gone.
It's a blue colour triangle Icon and worked flawlessly whenever I used it. It provides the voice based direactions as well. It's not Wisepilot.
I'm very dependent on this app.
Please advise how to get it back without resetting the phone, I searched for it on google play and couldnt find it.
Appreciate your help.
Thanks so much.
Siddharth.
Solved! Go to Solution.
worked like a charm. Thank you!!!
