Sony Xperia T has/shows wrong CPU/Board?
SOLVED
profile.country.nl_NL.title
silasje1
Visitor
Hey,
I stumbled upon a thread here: http://forum.xda-developers.com/showthread.php?p=41155069
It is about the Sony Xperia T saying it uses the MSM8960 (Used in Xperia V for example -4G) instead of the MSM8260A.
Here some screenshots to prove:
http://i350.photobucket.com/albums/q429/Silasje1/Screenshot_2013-05-07-20-52-16.png
http://i350.photobucket.com/albums/q429/Silasje1/Screenshot_2013-05-07-20-53-26.png
http://i350.photobucket.com/albums/q429/Silasje1/Screenshot_2013-05-07-21-00-54.png
Any Comments Sony? Do i have a Sony Xperia T with the wrong CPU/Board?
Message was edited by: silasje1
1 ACCEPTED SOLUTION
Accepted Solutions
Johan
Master
Correct chip set is MSM8960.
The white paper is going to be corrected accordingly.
3 REPLIES 3
Rickard
Master
The specification for the phone says that it has MSM8260-A but the file build.prop in the Xperia T software says it has MSM8960. I think the reason for system info apps saying it has a MSM8960 is because of the information in build.prop but i'll try to get some more information about this.
Johan
Master
silasje1
Visitor
Thanks! so in theory it can use LTE? (Unofficially)
