system registry cleaner app
SOLVED
danlock
Visitor
Hi, can anyone recomend a good safe registry cleaner? thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
you can clear the cache
settings > apps > all > tap on an app > clear cache
or
settings > apps > running > tap on an app > clear cache
or download an app to do it for you but keep an eye on the permissions such app require
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
4 REPLIES 4
Uliwooly
this is android not windows Dizzy_Face lol, you don't need a registry cleaner, can you elaborate on what you are trying to accomplish?
Uliwooly
or
danlock
Visitor
thanks again, i'll try that.
i thought the android cache would fill up with unwanted stuff much like a windows cache would. if it can be done manually than thats great.
Thanks for your help again Slightly_smiling_Face
Uliwooly
anytime
