Tethering error
SOLVED
kashyapkopparam
Visitor
Tethering error
Firmware: 6.1.1.B.1.54
I have 3G data enabled. I get the 3G/H symbol on notification bar.
If i try to tether wireless or USB , i get an error
Tethering Error
Error occured during tethering
I have reset the phone with full wipe.
I have repaired the phone using PC Companion.
But same problem persists. Please give me a solution to this.
20 REPLIES 20
KorayHepsen
Visitor
The problem is the APN settings.
Check all the APN settings on your phone.
If one of them has "dun" in "APN Type" field, your phone will use this APN setting for tethering.
Either remove this APN setting completely or if you can not remove the setting as me, clear this APN setting field.
None of the APN settings should have "dun" on their APN Type field unless you want to set a different APN account for tethering.
APN Type "default,supl" for the main APN setting is enough for most of the cases. Please check with your operator.
Hope this will solve your problem.
