the usb drive is not being detected when connected via utg. PLEASE HELP
SOLVED
varma_shankar
Visitor
When i connect the usb drive, the pop up which usually comes is not coming. And when i try to get into the usb drive using file manager(ASTRO) , it shows that the drive is empty( but the drive actually has data in it),
Slightly_frowning_Face
1 ACCEPTED SOLUTION
Accepted Solutions
varma_shankar
Visitor
i connected the phone to my pc in pc companion mode and then disconnected it after a few minutes. then when i tried the OTG , it started working. Thanks so much for your patient and timely help.
10 REPLIES 10
adarshgurjar
Visitor
u mean by OTG right ? Go to settings > Storage and check if there is any device shown under external USB storage, if yes, then your Drive is working fine, and might be possible that the data in it got hidden by viruses, and hidden files will not be shown by ASTRO
varma_shankar
Visitor
yeah i meant otg.. in the storage there is no devices in the external storage.
varma_shankar
Visitor
It was working fine till yesterday. and today it went all wrong. and now usb drive, mouse or anything of that sort is not being detected.
adarshgurjar
Visitor
then either your drive or the OTG cable is defected ! try connecting different hardware with otg cable to your phone
Not applicable
Kindly Select PC Companion mode for USB connection in cellphone 1st.
adarshgurjar
Visitor
dude, he is talking about OTG cable, not about usb cable !
kranthi1989
Visitor
Restart the mobile and try...
varma_shankar
Visitor
varma_shankar
Visitor
I don't know why my problem was resolved but by gods grace it is all solved. Anyboby who has my same problem ( whoes problem is not solved by this method ) should take advice from adarshgurjar and XperiaUuU.
