Hi, I want to report that Timescape does not work in my Gingerbread XPERIA sola a few days ago...
I did try:
1. Restart Phone
2. "Clear Data" of Timescape services
...and given with No. 2, I doubt that Master Reset the phone as well as updating the phone to ICS would do anything good...
...as it turns out that ICS XPERIA sola's user also has this problem...
http://talk.sonymobile.com/message/335670#335670
Adding my comment...
I think it's a server error (not sure Sony's or Facebook's)... Please fix it as soon as possible...
Regards,
Trubo
Solved! Go to Solution.
Thanks Dude!
Dont be panic just download it and install it and tell me if it works becuz its excellent working on my Xpperia S
link http://www.mediafire.com/?fl4p8f4vpx0jp16
Enjoy!!!!
Thanks for your answer i had install and now timescape work again on my xperia sola. have a great 2013
Hi, I tried downloading the Timescape app that you posted, but I'm still having the same problem
and I'm also using Xperia S on ICS.. thanks
It doesn't work...
...at ALL!!
I always getting Parse Error when I open up the file...
My guesses is that its for Ice Cream Sandwich and above (4.X)...
Since a lot of people saying that this one doesn't work (like Brian said - he's using XPERIA S as well), and I doubt that XPERIAsole said it worked...
I will NOT going to mark it Correct/Useful...
Regards,
Trubo
PS: Sony! I see that there's a tab under the phone's Update Center app called...
New Apps... Are you ever going to use that to update?
Or, Google Play??
Its working fine on my Xperia U .
Only installed EventStreamPluginFacebook.apk from the extracted file.
for more details check this link http://forum.xda-developers.com/showthread.php?t=2071646&page=4
Still doesn't work...
You guys should give up already...
These apps are meant for ICS (can anyone with ICS volunteered to check if it's working?) and it's not working on my Gingerbread XPERIA sola...
Other apps apparently looks like the same from the Mediafire site:
"There's a parse error while parsing the package..."
Regards,
Trubo
It doesnt work with Miro
I just wish that XDA Developers comes up with a fix for our phone versions
Thanks,
It worked on my Xperia U (ICS)
