Hello,
I m facing a strange prob with touchscreen....the top 0.8 mm of th screen doesnt seem to respond....i cant slide down the notification bar....after performing a settings reset it works fine.....only to recur again after a while.Cant find a particular trigger causing it.... Can anyone tell me if its a software or a hardware prob?and any permanent solution to this prob? (android version 4.04)
Thanks
Solved! Go to Solution.
it was probably a bug or an app acting up
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
repair your phone with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Thanks for the reply
....repairing the fone seems to have solved the problem....it was problem with screen callibration is it?
Thanks for helping me with this
anytime
