Update 4.1.B.0.431->4.1.B.0.587
SOLVED
jms061977
Visitor
Hi,
Yesterday my phone ST18i xperia ray show me the option to update to 4.1.b.0.587 but when I´ve performanced the update the phone has dead, the screen is black and doen´t turn on.
Is there any process to recuperate it?
Thanks.
1 ACCEPTED SOLUTION
Accepted Solutions
jms061977
Visitor
Thanks Veresova, this is the second time I get this error. The first was updating to 4.1.B.0.431. I had to use PC Companion in order to install the new version but after the installation I got the same situation. I solved it by flashing with unbrick but losing all the data phone. This is why I´m trying to find out how to update my phone without losing the data again.
5 REPLIES 5
Veresova
Contributor
jms061977
Visitor
Veresova
Contributor
Here is explained without losing data:
http://talk.sonymobile.com/thread/49683
Flashtool: unselect all Wipe
jms061977
Visitor
I´ve updated avec success and without losing any data by using SUS.
Thanks you very much Veresova
sundse58
Visitor
Hi Veresova, I have the same problem, update came last evening and since then no change to start the phoen. I also tried to update over PCC and SUS no change. The phone viberat short and flash short green. Could you help me also?
