Hi ,
When iam trying to Flash my Xperia S to the the latest firmware : JB 211, iam getting error as
( Device connected with USB debugging off for 2011 devices line, be sure you are not in MTP mode)
but the debugging is ON , can any one plz help.
Thank You.
Solved! Go to Solution.
Hi ,
I couldnot flash my XS using the beta version, i flashed through flashtool-0.9.11.0-windows...
Now the JB version is 211.
Are you using Flashtool and is it the latest version? and i'm not sure if this applies to Flashtool or Fastboot but Unknown sources may need to also be ticked
Yes its the latest version, even after ticked getting same error, do you know any other Flashtool of latest version....
