Weird language
SOLVED
Undefeatable
Visitor
Weird language
I need help over here Slightly_frowning_Face when i make a call and finish it and i get a msg with my current credit left and it appears in a very wired thing , so please anyone help me
Here is a screenshot:
1 ACCEPTED SOLUTION
Accepted Solutions
EowynCarter1
Visitor
Sounds like some encoding problem rather than language problem. SMS should be in english ? What language / region is your sola set to ?
You should contact you phone provider, as they're the ones sending that SMS. What app is that doing the pop up ?
2 REPLIES 2
EowynCarter1
Visitor
Undefeatable
Visitor
Fixed,  Thanks alot ❤️
