what do i need to hook my mini pro to a computer? and where do i get one?
SOLVED
Not applicable
sounds ridiculous, but i've been to the Source, Staples, and they say the usb cable is proprietary.  I contacted rogers where i bought the phone and they said contact Sony.  I mean really, the cable should have been incljuded with the phone.  so what do I need?  would rather buy it on ebay if I can.
1 ACCEPTED SOLUTION
Accepted Solutions
that's really odd, double check the part where you connect it to the wall, are you sure it's not a
micro usb on one end then USB on the other end that connects to the wall socket?
7 REPLIES 7
Shawhifox
Visitor
Propietary? Xperia mini pro, like the majority of the new phones, uses MicroUSB to charge and connect to a PC. It's a standard and easy to find. The cable you need is included in the box, the same you use to charge the phone (the one you attach to the wall charger). Just remove the wall charger and use it in the USB port of your PC.
any micro USB should do
Not applicable
Nope, my mini pro came with a cable which attaches to my phone, and the other end is a regular plug which I plug into my wall socket.  no other cable. and i had 1 which was defective, so i returned it and got another, and both only came with a cable that plugs into a socket.  both staples and the source say the phone connection is wierd -- rectangular, not narrow at one end, wider at the other.
it should look something like this
Sony Ericsson Xperia Arc Sony Ericsson Micro-USB Travel Charger EP310
Not applicable
never have been good with the detials, but i have to say the mini pro came with little directions.  thanks. I've never seen a usb/plug like that so i didn't recognize it.  Duh!
anytime Slightly_smiling_Face
btw
Make sure you backup everything
Backup & Restore app
Use this links to download the apk
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
