Whether xperia sp has floating touch or not?
SOLVED
pchetan2
Visitor
It seems like xperia sp has floating touch techonology. Sometimes when I keep my finger nearer to the screen,a small circle appears on the screen right below the finger and when I point the finger on to icons the open as if they were TOUCHED to open. I can also scroll web pages,move between touch screens.
this occurs only certain times but not all the time
Would like to know if floating touch exists for xperia sp and if exists,how to use it regularly
18 REPLIES 18
saurabh88
Visitor
We have to turn off glove mode and also restart
Muski
Visitor
Awesome 😄
I just banged my GS3 boasting friends with this function!! !
Neoikari
Visitor
The key is in the lock screen. It all depends on how the screen is unlocked. If you are as smart as I am it will take only 10 seconds to figure it out. Winking_Face
Sam93
Visitor
I have disabled the "glove mode". But when I'm using Chrome, something cuorious is happening. When I pass my finger near the screen, the labels or links of a web turned "selected" (like when you put the pointer on a link (facebook profile link and shows up the information of the person, photo, etc.) in your pc).
So the question is... What is it??????
Danial-mach1
Leader
This is a feature in chrome..with you can hover your finger on links and get their info or open sub menus...its like when you mouse over an object or link in pc
Sam93
Visitor
Ok, but sometimes it works and sometimes it doesn't
Sam93
Visitor
What is the name of that gesture/feature?
abhiambady
Visitor
go to settings,turn off glove mode .then lock phone and unlock it normally by swiping
inorder to reactivate,turn on glove,and then lock phone,unlock by swiping finger just millimeters above screen without touching.:-D
abhiambady
Visitor
no need to restart
