Going to buy new Xperia SP. Confused between the colors (red,white,black). Since there's a shortage of red and white color in local market, Only black is available here which looks very good to me. But, I dunno how red and white looks like as compare to black. Please suggest which color should I go for and why.
Thanks.
Solved! Go to Solution.
no one can answer that question, what you like might not be so for others and vice versa
Alright, I'll stick to black then.
One more question please: Where to buy?
Since online shopping seems cheaper as comapared to local market rates. Is it safe to buy online? If Yes, then please suggest me some reliable online shopping sites from which I can buy XSP. Does online purchased product can be serviced in any Sony service center or I'll have to send the product back to sellers address?
Thanks again.
if the phone is from another country then you wont have any warranty (by Sony)
