Wifi Stuck after using portable hotspot function
SOLVED
Sunnyman
Visitor
Can anybody help to solve this problem?  This problem started from last year end and without improvement after I recently upgraded to Android 4.1.2 with the most up-to-date software version 6.2.A.0.400.
Kindly advise.  Many thanks!!
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.PH.title
MarlonUk1
2 REPLIES 2
MarlonUk1
Sunnyman
Visitor
Thank you nolramlb!
The problem is solved after the re-installation.
Slightly_smiling_Face
