When i plug in my headphones the right channel doens't192.168.1.254work i've used 3 hhappymodeadphones so far and all of them had the right chaneel not working.10.0.0.0.1
hello @misnelstain5
can you try to run some tests
go to settings>support>Xperia tests
check if the microphone and speakers are running fine,
also if available if you have the free headset that came with the phone try to test if those are working properly.
