Xperia neo L can downgeade from ICS 4.0.4 to Gingerbread 2.3 ???
I want to downgrade because use the ICS is very lag T^T
Sometime open App slower......
Solved! Go to Solution.
the Xperia Neo L was released with ICS, there isn't a GB firmware for this phone, you could try to flash the Neo or Neo V's firmware, but it might harm your phone
No, it's not possible to install GB, unless you want to install a custom firmware by getting root access etc.
yes i dont think this phone can handle ics and want gingerb too
any other unofficial way for downgrade to gb
go to xda developers and see neo l firm
i alredy tried but neo l not booting
i think that firmwares(neo & neo v) not suitable for neo l hardware
xda haves only ics firmware
you could try to flash the Xperia play firmware, Someone use the Xperia play can boot the neo l firmware but the buttom back can't use
that's odd but good to know
