Xperia Neo MT15i and MT15a
SOLVED
Not applicable
What is the different between mt15i and mt15a??? i just flash my mt15a which just bought 2 month ago it is mean that my warranty broken???...after that, i check the phone detail, my phone become mt15i??? Can i roll it bak to mt15a after i flash my phone by using mt15i ftf files???
1 ACCEPTED SOLUTION
Accepted Solutions
the main difference besides the name is the 3G frequencies on which they work
MT15i900 / 2100
MT15a850 / 1900 / 2100 / 800
flashing other firmware (flashtool) does void your warranty, you might be able to reflash to it's original firmware
even if you use the MT15i firmware on your MT15a phone, the name will change BUT your phone will work as a MT15a
3 REPLIES 3
MT15i900 / 2100
Not applicable
Thx for the reply and information...
Anytime
