Hello! I’m from Karachi, Pak. I wanted to ask if there is any possibility that I could update my Xperia P 4.1 Jelly Bean, because I am checking for an update for the last whole week but no results and it says that your device is already up to date where as it isn’t and still running on ICS, please help me out, I would appreciate a reply from my fellow country mate. Thank You !!
Solved! Go to Solution.
you have 2 options
1) wait for the update
or
2) manually update your phone (flashtool)
Don't forget to mark the Correct Answers & Helpful Answers
This is how to manually update your phone
http://talk.sonymobile.com/thread/41609
aoa bro...without any hesitation do what uliwooly is saying...flashed jelly bean manually about a week back...n viola...works perfect....just read the instructions three to four times if ur doing it for the first time...maybe keep em open while u r flashing it...best of luck
any rough date for the 1st option
no one knows
Allas ! 4.1 Jelly Bean Updated, thaks to all the helpfull friends...
