Xperia Play will NOT turn on at all?!?!?
SOLVED
Not applicable
So I have had my Xperia Play for a couple months, no real issues til now. Went to check my phone and it would not turn on? I have had it on the charger for about 45 mins now and the yellow light turned to a green light(on the power button) but it still will not turn on or even show that it is charging or anything. Kind of confused and worried at the moment. I don't know if it is just that dead or what. I couldn't find any information on what the problem could be.
Anybody have any answers for me?
-ZAMBi
1 ACCEPTED SOLUTION
Accepted Solutions
slimshaddy
Hero
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
update your phone with this..
since you cannot see anything you cant backup your files..
updating will delete all the phone's data , memory card will not be affected..
if it says your phone is up to date click on install anyway..
do this and tell me the results..
3 REPLIES 3
Not applicable
Ok... update... my phone is on I believe just the screen went black... I can hear it recieving txt messages or emails or something but the screen won't turn on?
slimshaddy
Hero
slimshaddy
Hero
if the above doesnt helps , go to your service centre nearby to get it check for some hardware problems..
