Hello, Earlier today, as I went to unlock my Xperia SP, I realised that the screen would not turn on, no matter how many times I pressed the unlock button. I also tried plugging it in to charge to see if the screen would light up then, but the neither the screen or the LED light turned on. It's seems like it's completely dead! I don't really know how to tell if the phone itself is still on, however. It was at about 50% battery. I've had this phone for a little over a year now.
Could you help me resolve this problem? This phone is really important to me!
Thanks!
I am experiencing same problem right now.. my phone's dead for about 8 hours already but the battery was 80% loaded. It hung so I locked it, and when I decided to unlock, the screen is completely blank but the LED keeps on blinking everytime I press the power button. I tried everything listed here. But nothing happened
please help me.
Hi guys , after my phone crashing several times this morning its finally switched off with around 50% power, ive tried + switch and the onoff button, tried pressing off inside the back of the phone and still no joy, anything else to try? The phone is just coming up to its 2 year contract and has been an awful phone but its never been dropped, knocked or damaged, software seems to be crap and constant msg of transfer memory even though theres plenty on it and then it only lets you transfer photos vids files?
The 5 sec pushing down the "off" button while connected really worked for me in the end. It vibrated 3 times after I kept the off button pushed down for 5 secs with the back of a paper pin.
Nothing else worked until then. Thank you so much.
Thank you everybody. Mine was resolved by pressing the off button in back :smileyhappy::smileyhappy:
remove cover -> press off button with a pin until 3 vibreations felt -> try to start again
I have the same problem. My Xperia SP won't turn on/sudden death. I already tried alot of suggestions but nothing worked. The only 2 suggestions seemed to react. When I press Volume Down+Power button, vibrates and a green led light up, like a flash. When is plugged in, green led just keep it light up. Nothing more happened. The second one is when I press the button OFF+Power button, vibrates 3 times. When is plugged in, keeps vibrating 3 times. Still, nothing more happened after it...
What can I do?
thanks
I have pressed volume up+power button, and also pressed off button on back side but nothing happened. after pressing buttons my mobile doesn't vibrates.Please help me.
Hi,
I also have the black screen with white line it is a sealed unit so I cannot take the back off to reset. Do not know what to do have pushed the Volume Button and on button to get back to the black screen with a white line. Sony XA
hi i flash my xperia wrong and it never turn on and never charging when i conected to wall charger no red led light and when i press the power button it flash one time a red light any help how to flash it again
thank you.
