Does anybody else have any of these problems
1. Charges when it feels like it
2. Won't recieve any messages
3. Poor battery life
4. Won't let me use the market
5. Slow keypad
6. Slow operation
If so and you solved the problem let me know how as it is really annoying me 😕
thanks
Glenn,
Ireland.
backup everything and update/repair your phone with Update Service
http://dl-www.sonyericsson.com/cws/download/1/110/61/1315209439/Update_Service_Setup-2.11.9.6.exe
Make sure you backup everything
Backup & Restore app
Use this links to download the apk
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkhttp://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
thanks i tried backing it up before but no luck
il try the update service its downloading at the moment
try to sync w/ google
