8505b - Cannot stream HEVC / H265 videos
tvguy99
Explorer
I'd like to stream some videos encoded with the HEVC / H265 codec, but the TV won't cooperate - even though it has a compatible decoder chip.  Any thoughts on how I can make it behave?
1 REPLY 1
Anonymous
Not applicable
Hi there
As far as I believe, HEVC (H265) is only supported for 4K Netflix and the internal DVB-S2 tuner (satellite).  Not for file streaming.
The supported file formats and codecs for your TV can be found:
http://pdf.crse.com/manuals/14HA230111/EN/codeclist.html#5
Cheers
