Bluetooth connectivity
andrewjferry
Explorer
Hi, I have recently purchased the sony 32wd756bu thinking that it was an all singing and all dancing tv.. unfortunately not!! Instead it's classed as a smart tv.
Is there anyway I can connect my bluetooth headphones to this tv, if so how?
Many thanks
Andrew
5 REPLIES 5
Peter_S.
Genius
Hi Andrew,
Unfortunately that's not possible with this TV.
So you would need a BT transmitter that is connected to the headphones connector of the TV.
Cheers
Peter
andrewjferry
Explorer
many thanks Peter, do you mean a bluetooth dongle?
Joe_Dohn
Specialist
Yes, but you should definitely make sure it works before making a purchase (checking specs vs your headphones or checking reviews for example).
andrewjferry
Explorer
thanks Joe, usually they want you to download an app first..  which of course is not possible
Joe_Dohn
Specialist
That's very true.
If you care about the audio quality, I'd recommend looking at known brands (Creative comes to mind, mainly because I remember seeing one of their dongles on this forum, randomly enough).
Hope this helps!
- JD
