Bravia TV Home button not working?
JayPDC
Explorer
Hello, I was wondering if anyone knows why the Home button on my Sony Bravia TV remote no longer seems to work?
It used to bring up my options for apps and YouTube etc, but doesn't seem to be working now?
I have my TV linked to a Sky+ Box and the TV is less than a year old.
Any help appreciated.
Thanks!
Tags (3)
25 REPLIES 25
soulmonkeylove
Explorer
I had this problem for years and found that to enter the home screen I had to press the button at the top left of my Sony remote to show the input options, at which point as a result of entering the TV navigation the home button would work.
donaldac
Explorer
Cannot Access iPlayer when pressing Home button. Infuriatingly Photo Sharing Plus comes up! How do i delete this?
Andy1981
New
I have found a solution for this eventually 🤣🤣
So.....
If your home button doesn't work , do a factory reset.
To do a factory reset without the home button you :
1. Unplug the TV
2. On the TV itself - there should be 3 buttons (volume up , power , volume down)
3. Hold down the Power button and the Volume down button at the same time whilst plugging in the TV  (I had to get the wife involved ha!)
4. Keep the both Buttons held down until you see the Sony Logo appear on the screen (let go of buttons)  from there a factory reset will begin , you will have to setup country , wifi password etc again however , you will have your home button back and your TV will be updated to the latest software.
Hope this helps someone 🙏
Monkey_boy
New
I have a Sony 55a1 OLED TV. Owned since 2017. Recently Home button does not work. I've performed a factory reset, tried another sony tv remote and disabled all HDMI-CEC Control. HOME Button still does not work! Any ideas?
LightFoot
Specialist
Hi @Monkey_boy   I had an old Sony TV circa 2015, and when my Home button stopped working I called Sony Support and they instructed me to key in a sequence of keys on the remote, which bought back the Home Screen. Obviously, after 10 years I cannot remember what!
Monkey_boy
New
Thank you very much I'll try that. Cheers
