Hi I have a KDL-40Z4500 TV I would like to know if my TV is HDMCP COMPATIBLE as I have a apple tv and it won't play film trailers
Solved! Go to Solution.
Hi
Do you mean HDCP -http://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection ?
If so then yes - if you have connected Apple TV to the BRAVIA via HDMI cable then yes. I think HDCP is mandatory.
Hope this helps
Hi
Hope this helps
