- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Intermittent picture loss on BBC HD - 40HX723
Hi everyone,
I've just bought a new 40HX723, and it's generally very good - but some BBC HD programmes are virtually un-watchable, as the screen often goes blank for about a second between scenes!
I've done a bit of reading and discovered this is a known issue with BBC HD broadcasts - I've also discovered the iManual recommends setting the TV to "optimise for text/graphics" instead of "optimise for video".
However, when "optimise for text/grtaphics" is selected, the picture resolution as not so good as the "optimise for video" setting - although it does seem to cure the picture loss problem.
Does anybody know what the "optimnise for text/graphics" setting actually does?
Presumably it modifies the video processing in some way, defaulting the output to a lower quality format (OK for text, but not great for pictures)?
Is there a proper fix for this issue in the pipeline (e.g. TV firmware update)?
Many thanks,
Pete.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Agreed, not fixed yet.:smileyangry:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi can anyone advise if this problem has been fixed yet?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yup - just download the latest firmware either directly on your TV or via USB.
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm getting this issue on all HD channels on my new 55 hx853
If anything i think the latest firmware has caused it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Factory reset has done nothing for my picture
Back to Cust Services!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've just started getting the same blanking issue on all HD channels on my 55HX853, but only since the August 30th firmware update. I did set the 'optimise for video' at that time so will revert back to optimise for text/graphics to see if that helps. Otherwise it's incredibly annoying and happens several times in succession then not for a minute or two, dependent on the programme.
- « Previous
- 1
- 2
- Next »
