internet on 40w5500, through ps3 ?
SOLVED
profile.country.en_GB.title
tyhughe58
New
i have a 40w5500 tv and ps3. the ps3 is connected to the internet wireless.
is there a way of connecting the tv to the internet via the ps3. i know i can run a cable from the router to the tv but was wondering if the tv could connect to internet without running this cable. The router is a fair distance from the tv so running a cable would be difficult. thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
Member
Hi,
whichever way you have your PS3 displaying on the tv will display the internet content the same way.
1 REPLY 1
Bravia55HX
Member
Hi,
